I'll definitely keep an eye on the sensor as I drive it more. Car only has 25K so thinking this is likely normal (but new to me).
R.E92 said:
It's also quite common for the thermostat to get tired and let coolant pass on the N54. It's not a widely talked about issue but both my N54 cars had the same symptom at roughly 60k miles. In my experience BMW thermostats always fail open, I've done the same job on almost every one I've owned but the N54 is the most annoying since it's underneath the engine!
On the Z4 I used it as an excuse to replace the water pump as it was on the original. On my 335i it was taking a while to warm up but BMW had already replaced the pump just before I purchased the car so I just replaced the thermostat.
The easy way to tell is that on a good motorway run the oil temp needle should sit 1 notch under the midpoint. Any less and you have a lazy thermostat. Your car is almost certainly having thermostat issues if your oil is at 160f after 10 miles.
It's not an urgent problem, you'll just get lower fuel mileage and slightly more engine wear. You should also replace the water pump at the same time since it's only 3 extra bolts once the thermostat is out.
Definitely planning on putting more miles on the car. It's just the timing (new job) and s series of unfortunate temporary events that prevented me from driving it more.
Busterboo said:
spielnicht said:
Still new to my recently acquired 2011 35is having only put 200 miles over the past 2 months ...
So that's 25 miles a week, 1300 a year. Worth buying? :?
I bought mine at 10 yrs old with 24k on it FSH annual inspections by BMW and have had endless problems, the HPFP had already been relapced at 22k mies!
Hardly driving a car does not seem to add to its reliability and its probably fair to say it could make it more unreliable. Dry unlubricated seals and roller bearings, shells developing flat spots, bone dry oil galleries when its started, dried out gaskets etc etc
