Hi -
I'm the new third owner of my 2006 Montego Blue Z4 Coupe, and the immediate previous owner neglected a few things which I'm working to remedy. The windshield cowl was very sun-ravaged and brittle. When I removed it for replacement, I found a large dog-hair mouse nest on outer side of the cabin air filter.
Thankfully, the odor was gone, so I cleaned everything well and reassembled it with the new cowl molding. It now looks as it should - BUT I have a nagging question. There's a circular opening which drains the center portion of the Scuttle area (under the cowl) - it's in a low spot to the left of the car's centerline. This drains the area in which the windshield wiper motor and mechanism are located. Should that round port have a rubber drain grommet or some sort of screen ? This seems to be the 'back door' that a mouse used under the PO's watch to set up housekeeping !
For reference, I checked my good friend's 2006 Z4 Roadster. His car has this same opening with no screen or drain grommet. I cannot find any indication of a grommet or screen in RealOEM. Please respond if you can shed any light on this.
Thanks !
Thanks !
