PerryGunn said:Don't be lazy, take one off, remove the tyre and weigh it... sheesh! some people.... :wink:Darren Slone said:The rear wheels weigh 11.6kg / 25lb
And the fronts 10.6kg / 23lb if my maths is right, been looking online and can't find original wheel weights, I'll keep looking![]()
original guvnor said:Virtually spot on Daz.
OEM CSL front (ET 47) is 23.0lbs
OEM CSL rear (ET 27) is 24.2lbs.
Apparently the M3 CS rear wheel is identical to the CSL (same part number) but the front is only 8" wide (versus 8.5" for the CSL). I always thought the CSL wheel was forged where as the CS wheel was spun cast?
Darren Slone said:Thanks Tom, they're exactly the same, just want to check tyre sizes with you because my others are on 275/245 but am I right in thinking that 265/30/19 & 235/35/19 are ok too?
srhutch said:Darren Slone said:Thanks Tom, they're exactly the same, just want to check tyre sizes with you because my others are on 275/245 but am I right in thinking that 265/30/19 & 235/35/19 are ok too?
Mine are 265 and 235's
