On from cdv delete…
TIMMOS29
So as i was crawling under the car i wanted to have a look at the gearbox fluid refill drain points and was wandering if these are the right places…
The bottom one is the drain yes
The other is not the fill point
You are the wrong side of the gearbox casing
go the other side and look for the same style as the drain
Obviously don’t do anything unless you have located and opened the fill port!
New plugs come with ring gaskets. Also these are aluminium plugs, that's why replacement is recommended.
