nplenzick said:Hopefully having a 2012 2.0 delivered this Saturday. Can't find 0w-30 Euro spec anywhere near me in northern Arizona, only 0W-40 in Euro spec. Ok to use it?
I dont agree with that at all - saying one particular property of an engine oil is 'most important' is simply not correct.Zforbes said:nplenzick said:Hopefully having a 2012 2.0 delivered this Saturday. Can't find 0w-30 Euro spec anywhere near me in northern Arizona, only 0W-40 in Euro spec. Ok to use it?
0w40 has a greater temperature range so therefore as a grade would be superior to 0w30.
When buying oil the most important factor is how it breaks down over time, if you are buying something like Mobil 1 then you won't have a problem![]()
mcbutler said:I dont agree with that at all - saying one particular property of an engine oil is 'most important' is simply not correct.Zforbes said:nplenzick said:Hopefully having a 2012 2.0 delivered this Saturday. Can't find 0w-30 Euro spec anywhere near me in northern Arizona, only 0W-40 in Euro spec. Ok to use it?
If the OP deviates from what BMW - who make and extensively test the engine - then hes taking an unecessary risk.
I am completely sure that he can mail order the required correct spec oil without any issue at all.
He is located in Arizona which has quite an extreme climate in summer so adherence to OEM spec is probably especially important.
Exactly, if the oils viscocity peaked at 30 when 40 is recommended this would be especially critical in high temp environmentsZforbes said:mcbutler said:I dont agree with that at all - saying one particular property of an engine oil is 'most important' is simply not correct.Zforbes said:0w40 has a greater temperature range so therefore as a grade would be superior to 0w30.
As an oil grade 0w30 or 40 is simply the working temperature range, 0w40 has a greater higher temperature range than the 30, IMO that would benefit in an area like Arizona.
If the oil has a long life rating as suggested by R.E92 then all is good as it is tested and approved by BMW. These can be 0w30, 0w40 & 5w40![]()
mcbutler said:Exactly, if the oils viscocity peaked at 30 when 40 is recommended this would be especially critical in high temp environmentsZforbes said:mcbutler said:I dont agree with that at all - saying one particular property of an engine oil is 'most important' is simply not correct.
Zforbes said:mcbutler wrote: ↑Thu Feb 24, 2022 10:42 pm
Zforbes wrote: ↑Thu Feb 24, 2022 4:18 pm
mcbutler wrote: ↑Thu Feb 24, 2022 1:55 pm
I think we agree, op asked is 0w40 was ok if 30 was recommended, obviously it is.
