Oil Sump / Pan Leak
Mr Z
I have discovered an oil leak from the sump gasket on my 2003 3.0.
I will get my Indy to take a look but I was wondering if this is a difficult / expensive fix :(
(Is it engine out or sub-frame down etc etc?)
the subframe will need to be moved to access the sump gasket. The gasket is £15 from dealer. Garage should be charging no more than 2-3 hrs labour. Straight forward DIY if you have ramps
Are you sure its the sump? and not just the oil filter housing gasket. I did one last week and it looked like the sump but was the other as mentioned. Only cost £5 from dealer and will take you 1hr to DIY
