mr wilks said:I would expect 5w30 would normally be the most used spec for that car
Jfgoldfish said:mr wilks said:I would expect 5w30 would normally be the most used spec for that car
5w30 isnt really an oil specification. It's a grade/ viscosity. You shouldn't just throw any 5w30 in and expect it to perform as well as any other.
I believe BMW specify an oil that meets longlife-01 for your zed.
I don't think the oil you posted has been approved to that spec but it does meet other comparable specifications such as VW 504.00/507.00 which is the VW long life specification. I doubt any harm has been done. It should be a quality and quite suitable oil.
I am sure you are being sensible and changing it twice as often as BMW recommend anywayso I doubt it will start breaking down in there.
mr wilks said:Jfgoldfish said:mr wilks said:I would expect 5w30 would normally be the most used spec for that car
I was merely meaning that generally 5w30 would be the norm not 0w30 would it not ? no need for the aloof pedantry rant .
Jl-c said:mr wilks said:Jfgoldfish said:5w30 isnt really an oil specification. It's a grade/ viscosity. You shouldn't just throw any 5w30 in and expect it to perform as well as any other.
the dealers don't seem to agree, my car was on BMW 0W-30 oil when I had it. It's not now 5W-30![]()
skelters said:Best thing to do is go onto Opie Oils, put your REG in and select Millers Oils NANODRIVE EE LongLife C3 5w-30 Fully Synthetic Engine Oil.
Order enough for the car along with a filter!
Been changing the oil every year and this is all that goes in the Z4. Never had to top it up and there are no leaks either.
Always had excellent service from them.
https://www.opieoils.co.uk/
Wow, you really took that one the wrong way. :roll:Jl-c said:no need for the aloof pedantry rant .
Jfgoldfish said:Wow, you really took that one the wrong way. :roll:Jl-c said:no need for the aloof pedantry rant .
For the sake of not pushing any more of your buttons I will admit that I might have misinterpreted your post!
I am happy to admit that I am rather pedantic when it comes to oil in my car's. Best way to be IMHO.
Well we can certainly agree on that. Unless I picked it up at a very good price.mr wilks said:I wouldn't use Castrol though
Jfgoldfish said:Well we can certainly agree on that. Unless I picked it up at a very good price.mr wilks said:I wouldn't use Castrol though
As I say, I do think I misread your post. No offence was intended.![]()
I use Millers Trident, does the trickmr wilks said:skelters said:Best thing to do is go onto Opie Oils, put your REG in and select Millers Oils NANODRIVE EE LongLife C3 5w-30 Fully Synthetic Engine Oil.
THE END
Or if cost is a factor then Millers Trident 5w30 full synth , £26 for 6 litres
Well this is just getting confusing!mr wilks said:Errm not me!
enuff_zed said:I guess that's what you'd call a 'slick' apology :wink:
