hawkeye00021
I've already done a google search and looked through the forums here and I found one similar problem but it doesn't match me perfect nor do I think a resolution was ever posted.
We are having a bit of a heat wave for this area, temps are near 100 with much higher heat indexes. I find that when I drive my car for about 30 minutes that my temp gauge moves up to about 3/4 and what that happens while I'm at a long stop the oil pressure light sometimes kicks on... I even had the engine try to die on me once.
With that said, the oil pressure light has also been flickering when there would appear to be no issue at all.... it flashes so quickly it's hard to believe it's not a faulty sensor, but I did have the one instance of the engine almost dying. I pulled into the garage after the temp gauge had made it to 3/4 yesterday and the engine fan shut off immediately as if there was no need to keep cooling. The shop I have taken it to seems to think the cooling system is working just fine, and I just had a new radiator put in as part of an insurance claim (it was overheating before that).
I'll be taking it back to the shop today or tomorrow but they have had trouble duplicating the problem. In the mean time do you guys have any ideas?
*I should add that this seems to only happen with the AC on or long trips*
