How can a mechanical dipstick fail? :?AndyBeech said:Like all things electronic or mechanical it can fail, why I said both is the ideal. I'd still rather take electronic though personally!
Smartbear said:I've heard of some bmw dipsticks snapping in half & the broken part falling into the sump :thumbsdown:
We'll agree to differAndyBeech said:Smartbear said:Anyway, I'm not arguing about it, I prefer electronic, you prefer mechanical, cool beans!
thepits said:We'll agree to differAndyBeech said:Smartbear said:Anyway, I'm not arguing about it, I prefer electronic, you prefer mechanical, cool beans!![]()
p.s. just as a matter of interest, how many broken dipsticks do we know -v- rebooted computors? :lol:
Having the same question here : checked the level the other day and it showed 3/5. Still not sure if I should top it or not yet, and also important, how much should I pour in..?NathanZ4C said:Or on the basis that it's within reasonable limits do you leave it until it tells you to add more?
PerryGunn said:The other advantage of having a manual dipstick is that the tube allows you to use an oil pump, this means that you can do an interim oil change from start to finish in about 20 mins without getting under the car and having hot oil jet up your sleeve as you remove the plug :lol:
They're great for interim changes - I have full plug-out changes at the prescribed service intervals but I also do extra oil changes inbetween and an oil pump makes it soooo easyronk said:PerryGunn said:The other advantage of having a manual dipstick is that the tube allows you to use an oil pump, this means that you can do an interim oil change from start to finish in about 20 mins without getting under the car and having hot oil jet up your sleeve as you remove the plug :lol:
I've never liked those things.
I far prefer the tried and tested method of getting it all piping hot and letting it all whoosh out including any sediments and all !
They're not hard to remove, especially if the car's on a lift - but they take time to remove/replace and if a garage can do the job in half the time without needing time on the lift...ronk said:Ah, those undertrays !
I suppose they are a nightmare.
NathanZ4C said:If the oil level is showing at 50% should you top it up and if so how much?
You should find that there's sufficient oil for the most enthusiastic driving even when the oil level is at 'minimum' - the engineers aren't stupid and wouldn't set the levels without leaving a reasonable safety marginNathanZ4C said:Thanks guys. I worry about having slightly too little oil in there for when driving hard. I would prefer it to be over half way to reduce the risk to oil starvation during heavy corning if its likely to happen.
If a typical full oil capacity is about 6.5 litres, 1 litre is approx 15% of capacity - or looking at it another way, your oil level is still at 85%NathanZ4C said:Yeah i guess your right. Im probably just being over cautious Its just a litre seems like a lot of oil not to have in your engine
