So have replaced the oil/water filter heat exchange o ring twice.
First was after market but leaked shortly after.
So tried again with BMW original, all fine.
Then started to see odd tiny drip on floor.
Asked Mot guys, they said could see anything.
I looked back at seal around filter, reasonably dry.
Looked slightly wet along the cylinder head gasket, sort of grey rubber.
But behind looking between inlet manifold the engine wall was wet with oil.
Washed it off.
Now i can see patch forming on cast rib.
Hard to see where it originates.
So just lying in bed thinking i wonder if the engine not getting up to temperature driving to work 7 miles daily.
Temp. barely reaches 90. I know we can see 110-120 mid summer.
Wondering if a good run will tighten things up and stop leak...or make it worse!
In the old day i would put sheet of cardboard in front of radiator to get temp. up.
Does the 35i version have shutters on the radiator.
Tried to access realoem but seems blocked.
Washed it off.
