Hi everyone,
My 2003 Z4 has an oil leak from the engine somewhere. I had the MOT done recently and the mechanic said it looks like the leak is from the rocker cover gasket. I'm planning on doing the work myself but a friend suggested I should clean the engine block with a jet wash to check where the oil is coming as it may be something else.
Is that a good idea? I'm worried about getting high pressure water into the engine block or other components. I'm not sure how else to confirm whether its the rocker cover gasket otherwise. Any suggestions?
Also, any advice on changing the gasket would be very useful as I haven't done it myself before.
Many thanks for your help,
David
David
