Oil leak
jabber
Veteran
 Hampshire
Right now I know where the oil is leaking from does anyone know if this rubber gasket can be replaced without taking off the whole valve cover
Its simply a round rubber ring, I believe you can gently pull out the sensor (not by the cable) twist it gently. The rubber ring will come out and the new one POP in.
Item number three on this page
http://www.realoem.com/bmw/enUS/showparts?id=LM53-USA-06-2010-E89-BMW-Z4_30i&diagId=11_3737
