Oil leak help
Wipe it all clean. Go for a little drive until it's warmed up. Park it on the level. Open the bonnet and let it cool down. Carefully look and/or feel around the rocker cover gasket as I would definitely think that is the number one culprit if oil is dripping onto the exhaust manifold. It may have been fitted incorrectly/nipped or possibly be a cheap/inferior quality item. Was RTV sealant used on the quadrant sections ? :thumbsup:
The replacement of the rocker cover gasket would be my concern too as it probably wasn’t fitted correctly. At least that would be an easy fix.
kowsmou said:
Buckz said:
what engine/
Sorry, it's the 2.0.
It's quite common for a rocket cover gasket on the 2.0 to still leak after replacement. This is due to the cover itself warping ever so slightly. The solution is a new cover which is expensive or simply use some liquid gasket/sealant on the rubber gasket to get a good seal.
MACK said:
kowsmou said:
Buckz said:
what engine/
are additives ever good to resolve this?
