M merlintilly Member Feb 21, 2024 #1 I appear to have a fluid leak from the bottom edge of the oil cooler. What is likely to be the cause and how is it fixed, do I need to replace the whole steering system cooler?
W Wassup Senior member Feb 21, 2024 #2 Perished seal perhaps? Start with that before replacing the cooler. Had this issue on my M3 and it was a relatively cheap fix.
abar121 Active member Feb 22, 2024 #3 Clean it all up first to help identify what is leaking. Hopefully just as seal as above.
