czechT698 said:
thanks for the suggestions guys, will run a couple of test later on
One more question, is it normal that the oil smells like gas a little when engine is hot?
Possibly
If your rings are good, but don't do any long trips, just real short trips where the engine never really gets heat soaked, then it is possible.
Even with good rings, you will always get a little blow-by into the crankcase. Why do you think you have a PCV system.
If you don't take any long trips, oil dilution is possible and it could have a slight fuel smell.
When you drive longer trips, the engine gets up to temp then 'heat soaks' allowing the unburnt fuel to evaporate out of the oil. Remember, the coolant system only flows around the cylinders and not the crankcase. I have seen engines that were at operating temps (by the gauge) but still had frost on the lower block.. Really weird....
BUT
If you have worn rings, you may be getting more blow-by than normal and have more oil dilution than you really should have.
Also, your rings could be good, but are kinda 'stuck' with blow-by contaminants and not sealing well. Detergent oils are supposed to keep this from happening. In that case, you need some type of engine cleaning to really clean the engine out to allow the rings to get a better seat, or you could have some cylinder wall glazing which does the same thing.
The only engine cleaning system I really like is the Auto-RX system. http://www.auto-rx.com/index.html
I really don't like any of the 'flushing' systems where you replace your oil with the flush then run the engine.
