If it’s oil leaking from the plastic cap then yes, the oil filter cap o ring is leaking, oil filter housing gasket is usually referred to as the gasket between the housing and the engine block.
There’s 2 gaskets there that are prone to leaking. Mine was leaking pretty bad last year. The oil filter housing and the oil cooler gasket. The arrow is pointing towards the oil cooler gasket.
