Hi,
all filter housing gasket was leaking took off the housing unit and gasket was rock hard.
Replaced with genuine bow gasket, which does not really stick out that proud. I have tightened the 3 bolts up, did not get to 22nm as stated in the guide as I don't want to break bolts etc. drove to work today and checked after 30 min drive and still leaking.
if I tighten up to 22nm on the torque wrench is there no chance I will sheer bolts? is it worth applying gasket sealant?
any other ideas? is this normal with this gasket?
Thanks.
Thanks.
