No not for the zed :roll: - would be for our old campervan - went in for a MOT and oil change - passed MOT with no advisories
but they said when they went to unscrew the oil sump plug it part turned and then became hard to turn so just did it up tight again because of the danger of cross threading
strange as I thought you could only cross thread when tightening :?
I know I may be able to get an over sized drain plug but as it's aluminium might end up having to get a new sump
so thought about getting an oil extractor pump - apparently you can drain the oil through the dip stick - sounds a good solution but do they work ?
