A
Anonymous
Guest
Changed the oil cooler gasket today.
PITA
3 hour job because of the tight awkward spaces. Worth it though. Was causing over heating which I initially thought was the waterpump or stat. Turns out she was pissing coolant and oil out at over 4500rpm.
Now probably going to need a new serpentine belt because I spilt oil all over this one while taking off the cooler. Would brake cleaner be a good idea to use to clean oil off the pulleys when replacing the belt.
PITA
3 hour job because of the tight awkward spaces. Worth it though. Was causing over heating which I initially thought was the waterpump or stat. Turns out she was pissing coolant and oil out at over 4500rpm.Now probably going to need a new serpentine belt because I spilt oil all over this one while taking off the cooler. Would brake cleaner be a good idea to use to clean oil off the pulleys when replacing the belt.
