strugglinauthor said:
Nictrix said:
To the original question I am sure that in the manual it states that an oil change should be done every year as well as what the car asks for.
Its not very clear though and you will have to hunt for the info.
Interesting.
I'll have a wade through my manual tomorrow..
I've gone through every oil reference in the manual/handbook as I have a PDF version stored. At no point does it advise you should change the oil every year, it only makes reference to additional changes of oil when storing a car and by storing BMW mean 3 months or longer. However there could have been changes made to the handbook over the last 6 years so I'll also check the paper version.
It reads as follows:
Storage periods
Storage periods during which the vehicle battery was disconnected are not taken into account.
If this occurs, have a service center update the time-dependent maintenance procedures, such as checking brake fluid and, if necessary, changing the engine oil and the microfilter/acti‐ vated-charcoal filter.
It also has this
Maintenance
BMW Maintenance System
The system obtains information about the road safety and operational reliability of the vehicle and takes into account aspects such as a timely vehicle check. The aim is to optimize maintenance procedures with a view to reducing the cost of running the vehicle.
Condition Based Service CBS
Sensors and special algorithms take into account the driving conditions of your vehicle. Based on this, Condition Based Service determines the maintenance requirements.
The system makes it possible to adapt the amount of maintenance you need to your user profile.
Details on the service requirements, refer to page 69, can be displayed on the Control Display.
Service data in the remote control
Information on the required maintenance is continuously stored in the remote control.
Your service center will read out this data and suggest the right array of service procedures for your vehicle.
Therefore, hand your service specialist the remote control that you used most recently.
And on page 69 it also does not state re adhoc servicing, it just states how it is displayed on the dash and iDrive system and how to read it.
Supposedly the oil used is 'long life' oil however if you don't drive the car on a regular basis or drive it hard, then changing it more often is a better idea. Considering the E89 has no dip stick it's a bit difficult to check how the oil looks without taking the oil cap off.
