Good day all,
Please bear with me as this may seem a bit of a newby question.
My 64-plate 20i is a bit of a garage queen, although it has been pressed into service a few times throughout winters and bad weather. However, it still only has about 24k on the clock.
It also had a 5 year maintenance package on when I bought it, which only ran out in November. At that point it had an MOT and a brake fluid change. Since then it has only been out a couple of times.
Yesterday I noted that it is highlighting an oil change needed at 5/20. Checking back, it has done about 4k since the last one, so this must be a calendar based notification. This leads me to a few questions for you knowledgeable types.
1. How simple is an oil change on this car? I can get it up on axle stands, but only the front end. Will this allow full draining? How easy is access to the drain plug.
2. If I leave it for now, I will obviously get the warning cropping up every time I get in it. Can I reset the reminder? How? If I do, will that upset all the forecasting? I assume it will reset the mileage frequency too?
I do really want to farm out something like an oil change if it is simple for me to do in my garage, but it is all the resetting of reminders that appears to be the issue, at least to my 1980s-style car mechanic mind.
