This is an embarrassingly simple question, but after reading much ado about the subject (without any credible information), does anyone have a step by step instruction for an oil change on the Zed? I plan to use Castrol Edge 5-30W, and have heard bad things about Fram filters(??), so I guessI will bite it and go to the stealer for the filter(other recommendations?). Other questions:
1. Oil drain plug (17mm) location? Little door under engine?
2. Will I need to reset service clock?
3. Any particular issues with filter change?
4. Filter housing wrench size (32mm?)
5. Any other secrets I should be aware of?
I plan on pulling the car upon ramps (yes I have some that fit), but don't have a Mityvac or similar,so I plan on removing drain plug. I have done this many times on other cars, but first time on the Zed. Just can't stand the thought of 7500, or 10,000, or 15,000 miles between oil changes.
Thanks.
Thanks.
