Oil change by vacuum
AnthonyW
Hi. I'm going to change engine oil by vacuum extractor. In my previous cars, I dip the suction hose into the hole, in which the dipstick is located
However, there is no dipstick in G29. Any idea about where to suck the oil?
Thanks!
Pretty new on the forum but i have looked at DIY oil change and i am sure the method you suggest can't be used...
R60BBA said:
scootr said:
R60BBA said:
Is there not a sump plug?
There is but then all the oil would come out :?
Yes and...?
The OP wants to do an oil change? Or am I missing something here...?
I was being silly - OP doesn't want to crawl under the car and drain the oil. He wants to extract the oil from above.
Thanks!
why not just do it properly :thumbsdown:
Thanks!
+1 :thumbsup:
I don’t know whether this is true, but I have heard that you can never get all of the oil out of the engine by sucking it out from a vacuum extractor.
Especially on cars with baffled sumps, which means that you are unable to get the “dregs” at the bottom (which is the part of the oil which you most want to flush out of your engine during an oil change) hence why it is more preferable to drain from the sump plug...
Here are the motivations that I like to use vacuum. Glad to have more discussion:
1. I have done an experiment before on my Audi. I have drained under the car until the oil doesn't drip out. Then I immediately apply vaccum from above. It turns out that there is a ~0.1 L of oil residual extracted by vaccum. Maybe this problem is specific to the configuration of sump(?). Not sure G29 is the case.
2. Consider Stoke's law, the velocity of sedimentation of particle is inversely proportional to the square of particle size. For fine debris, it's practically difficult to wait until all debris settle. So my idea is to suck them when they are suspended in oil, and that I do vaccum on a hot engine. The debris / sludge alternatively suspend and circulate in hot oil.
3. Also similar to 1 & 2 above, there is always oil remains in the car. You can never drain / vacuum all of them out.
4. I do oil change whenever I feel that the car does not run smooth as if I just complete oil change. In general, I change it in 2500 ~ 3000 km (probably due to my driving habit). Given this frequency, I prefer a quick job of vacuum.
5. When I go to the dealer in every 10,000 km, they will help me to drain from bottom. So it's 3 to 4 vaccum then 1 drain.
But a lot of garages don’t just drain the oil they flush it through which ensures you get all of the old oil and any debris out of the sump. So I don’t think your argument works.
You think? I'd have said that was an exception rather than a given, most garages seem do the bare minimum in terms of servicing in most peoples experience from what you read on forums
With regard to point 2, I always do an oil change by draining from the sump plug, with the engine hot anyway.
Undo the plug at arm's length and try to keep your elbow at least as high as your hand so it doesn't run back. Have a couple of rags ready and it's easy.
I've never heard of a garage flushing oil through unless you specifically ask for that - indeed there is a risk that doing that can dislodge sediment that otherwise would never be a problem. Specific flushing oil exists but can cause the same problem and I'd never use it on a modern engine - i was scared using it on my old 850 Mini before i knew any better!
I vac mine out through the dipstick tube simply because I don't have the kit to raise the car high enough for me to safely get underneath. Last time i measured what came out and it was close enough in volume to what should have been there for me to happy I'd got more than enough out. The dipstick is showing that the new oil is still nice and clean so thats good enough.
One disadvantage is that you don't get the opportunity to inspect the magnetic sump plug for debris.
Since there is no dipstick on a B58 engine is this a moot / irrelevant point? :headbang: :tumbleweed: :poke:
As you said I think it depends on the engine and in particular the design of the sump.
Some of the newer cars don’t have a drain plug and so the only way to take out the oil is via a vacuum.
I am also hearing that this is the preferred method for main dealers, even on cars with sump plugs. However I am also hearing that it is preferred because it is faster and BMW main dealers are only giving their technicians 9 mins to do the oil changes.
I’m not sure if you are aware but quite a few of the people who I know that have worked at various main dealers in the UK have confirmed that in essence technicians get points (which translates into £££) for doing jobs as quickly as possible, yet there are no bonus points for being super thorough etc - which in turn creates an incentive culture whereby techs often ‘cut corners’ to do jobs as quickly as possible for bigger bonuses.
Yes you are correct in that you will never get all of the oil out of the engine upon an oil change, but for a car with a baffled sump the preferred method is to drop from the drain plug.
Perhaps you should try the test you did on your Audi to your Z4?...
Out of curiosity I decided to Google this and found this video.
It basically confirms what I was saying above:
[youtube]kZU8VzdHlCY[/youtube]
When I started using my PELA pump I was surprised to find that ai was removing more oil than by previously draining via the sump. I made a post about it after sucking out 7.5l, where I should have been removing 6.5l or less by using an extra step of going back the following morning to to suck out any residual oil that had drained down into the sump overnight.
It’s now my own preferred method.
https://z4-forum.com/forum/viewtopic.php?f=2&t=111405&p=1608746&hilit=Pump#p1608746
Maybe you could tap a hole into the side of the sump and make your own dipstick tube? :lol:
Yw :thumbsup:
