I changed the oil at the beginning of this spring. Maybe had 50 (max) starts with the leaking injector. Oil level on the dip stick did not get higher in that amount of time so I figured not a whole lot of gasoline went into the oil pan from the leaking injector...But, do you think it is necessary to change the oil due to the fuel leak?
The new injectors seemed to have solved the starting problem but I don't want to cause major damage to the bearings etc. for want of a $90 USD oil change.
What would you do?
What would you do?
