Can you help please with possible reasons and remedies
I took my 2008 Z4 coupe down the A1 from Leeming Bar to Boroughbridge and on both occasions I experienced the same issue
Car was ok when I left home no judder or brakes locking on or rubbing, after entering the contra flow at 50. The steering started to wobble and vibrate a bit like losing all you wheel balancing and this continued for about four miles, I then came out of the contraflow and speeded up and down and applied the brakes and judder was still there
I pulled of at Boroughbridge after approx four more miles and stopped
All wheels except front offside where cool, offside was pretty warm in the alloy wheel and the tyre and there was a smell like when you push it a bit and use the brakes
So started car and drove again and wheel and tyre coolant the same temperature then for the rest of the 100 mile journey to and from Manchester
I run the car regularly and at no other time except on this stretch of road has it done this and the wheel and tyre has got hot
Thoughts please, in my mind if it’s the wheel bearing it would be there constantly, if the brakes were binding I should notice, tyre pressures are fine and Bridgestone are ok tread wise
