Pretty sure they are 296M. Nearly as prone to crack as the famous 326Ms.B21 said:Another one bites the dust…which model of BMW wheel is that?
Marcoose said:That’s what happens when you don’t replace the air in the tyres with winter air.
Pondrew said:Pretty sure they are 296M. Nearly as prone to crack as the famous 326Ms.B21 said:Another one bites the dust…which model of BMW wheel is that?
mcbutler said:Its a quick fix, drop it down to a local engineering shop, they will nip round the back, weld it up and back in a few hours. Had mine done, weld is stronger than original cast.... No need to repaint inside edge
Yep, but it isn't the weld that'll crack next time.mcbutler said:... weld is stronger than original ...
