Umfaan said:Rob ..are you changing just the Dial faces over..as changing the complete unit will enable the dreaded Black Dot. Changing only the faces over is your best option..easy enough.
KPH Faces are available.EBay is your friend here.
Silverstar said:I am in the same boat UK car in Spain so I change the dial faces for some high quality ones from Venoxy. Looks much cleaner and easier to read with just KPH on the dial face. A tad bit expensive but the quality is on another level compared to the ones you get on eBay, also can be reverted back to standard at any time without any damage.
Sludgepump said:https://www.youtube.com/watch?v=lbj2tSZvzI0
I guess you've seen this video?
Robster68 said:Silverstar said:I am in the same boat UK car in Spain so I change the dial faces for some high quality ones from Venoxy. Looks much cleaner and easier to read with just KPH on the dial face. A tad bit expensive but the quality is on another level compared to the ones you get on eBay, also can be reverted back to standard at any time without any damage.
I looked at venoxy and they seem to offer gauges for e89 only,I really want to keep it oem and have seen a lhd cluster on eBay so will probably go down that route at least I’ll have some spare bulbs![]()
I’ll see if I get a reply from this eBay seller first,a polish company called moman do them also,a fair bit cheaper than venoxySilverstar said:Robster68 said:Silverstar said:I am in the same boat UK car in Spain so I change the dial faces for some high quality ones from Venoxy. Looks much cleaner and easier to read with just KPH on the dial face. A tad bit expensive but the quality is on another level compared to the ones you get on eBay, also can be reverted back to standard at any time without any damage.
Venoxy do them for the E85 as well, if it isn't on their website just drop them a line. They can do faces which are an exact copy of the original too.
Moman €48Silverstar said:Just had a look on their website, prices seems to be similar. If I remember correctly it cost me around 50€ But looking at their website I think either one Moman or Venoxy you wont go wrong.
