Odd handling at speed
mct
 Bedfordshire
Hi,
I’ve just got myself a Z4 e86. Very pleased with it apart from the fact that it wanders significantly above 60 mph. Now I’ve just noticed that it has non rft’s on the rear axle and rft’s on the front. Could that be the issue ? Is any one else running a similar combo without any issues ?
It has new shocks, new track rods and suspension bushes and the tracking is good.
Any thoughts ?
Thanks,
Mark
And ending point. Get those run flats off immediately.
Currently your front axle is sniffing out all minor surface imperfections and following them, while the rears are just staying their course.
Agree get rid of the ditchfinders on the front see if that improves things.
I've got RFTs on the front and non-RFTs on the back and it drives brilliantly. Straight as an arrow well into license losing territory. The ride is also no worse than with non-RFTs. They're Merc spec Bridgestones FWIW - Chinese random name stuff is a lot stiffer and crashier.
However, it won't be tyres, and if they've done the front lollipop bushes then it's probably the RTABs at the back. They tend to get forgotten about and they make it feel as though the front is wandering about.
Thanks for the suggestions. They are Bridgestone rft’s on the front (fairly new) and Uniroyale rainsport 5’s on the back (new). I’ll get them to check everything front and back first then think about changing the tyres.
Those of you with non rft’s - are you carrying a repair kit etc or relying on rac/aa etc in the event of a puncture?
When I had my 3.0Si I had a space-saver that I bought from another forum member who had sold his Z4. E46 3 Series have them, but it needs to be a 17" one from a 330i or 330d to fit over the front brakes on a 3.0Si. Other models only had a 16" one. An E46 jack also fits the jacking points perfectly.
M's don't have run-flats, just a "Mobility Kit" which is a can of gloop and a compressor. As I often do trips hundreds of miles from home I've bought a full size front wheel for mine which takes up a lot of boot space but would mean I wouldn't be trying to find a tyre in the Scottish Highlands and could continue my trip without any 50mph or mileage limitations.
I still have the Mobility Kit and RAC Membership as Plan B and Plan C though. :LOL:
Some people have used "Rats-tail" plugs and a compressor too, but I'm not confident about my abilities with those.
