I have had a rummage round on the forum but can't quite find anything that matches the problem on wifey's 2.5i.
Press the key to unlock the car, nothing happens.
Press the lock button and it makes a noise as though it's relocking, and there's the audible beep.
Boot button works fine.
If I put the key in the lock and turn it to unlock, it only unlocks the drivers door, as I think it should. Then turn the key back to lock the car again.
If I then press the unlock button it all works properly.
But then lock the car with the key fob and sometimes it repeats the same issue, but not always.
When the issue occurs, if I open the drivers door with the key and get in, the central locking button won't work either. This also comes back to life after the relock-unlock as above.
So, is this likely to be the key battery? (Don't have a spare to try on this car). Seems odd that it always locks ok, but won't unlock.
Or is it something in the drivers door lock that isn't quite making a connection?
