Did you set-up your suspension rather soft...and a bit softer at the rear then the front?dannyg_m3 said:Thanks very much.
You'll be surprised how much difference the KW's make.
You'll be very close to 8 minutes at least
I'm on the middle setting of my Bilstein PSS-10...any harder and it lowers the grip in my experience...but a bit softer at the rear seems to work better.dannyg_m3 said:Suspension is quite hard really, however the rear compression is a couple of clicks softer than usual to make the car a little more forgiving...
Thanks for the feedback.
Ditto - my Ring setting is 6 front and 4 rear (day to day is 2 clicks lower for both).Franzino said:I'm on the middle setting of my Bilstein PSS-10...any harder and it lowers the grip in my experience...but a bit softer at the rear seems to work better.
You also have a Bilstein PSS-10 on your Z4M?mmm-five said:Ditto - my Ring setting is 6 front and 4 rear (day to day is 2 clicks lower for both).Franzino said:I'm on the middle setting of my Bilstein PSS-10...any harder and it lowers the grip in my experience...but a bit softer at the rear seems to work better.
I did try 10/10 - but it ends up skipping/slewing all over the place (on PSS) and gets very light on crests (especially at 140mph-ish on the bump just before Schwedenkreuz).
Probably don't see anyone else from here at the track as I've usually done 4 or 5 by 10am, then go off and drive around the area for a few hours, have a nice lunch somewhere, and then go back around 5pm for another 4 or 5 laps before it closes for the evening.
Tend to miss most of the fuckwittery and 1-3 hour closures that way.
Yes.Franzino said:You also have a Bilstein PSS-10 on your Z4M?
