noisey fuel pump
madmutt0
hi my fuel pump has just started to be a little noisey
should i change it or is it something i can live with also on a 07 2.0 l is the pump in. the tank i cant hear it outside but i can when sat in the car
thanks for any advice
Get some Red x petrol treatment,pour half the bottle in the tank(about 100ml) this will cure the noise.Worked for me in the past,noise never came back. :thumbsup:
my pump (3.0 M54) is noisy when the tank is almost empty. I suspect as the fact that when less than almost empty the noise is obviously insulated by the fuel present in the tank.
Same for the 2.0?
If you could see in the fuel tank on these you wouldn’t let it go much below 1/4 tank . Fuel does a massive job in keeping the pump running cooler .
Had the same with mine last month. Mechanic said it was probably trying to purge air from the system and told me to fuel it up a bit and go for a run. Noise hasn't been back since.
