Maybe thats a side effect of battery going low on voltage ?
Seriously,if you have a battery charger,give it a slow charge overnight... Nothing to lose..
Also..... you could try a reset of the control module.... You need to disconnect BOTH battery leads and then touch the leads together briefly,this flattens all the caps in the cars modules.
Reconnect and see if the controls and lights work... Again,nothing to lose..
Edit...
By the way.... do you start the car by pressing brake,then hitting the start button ? If so,reverse the process.......press the button and then press the brake to start the car.. In the US they call it "T" fix and can sort out all kind of electrical issues......
