I've owned this 2003 for about two months. It's been an adventure (and I say that unironically). I've enjoyed working on it.
However, I've got a problem that keeps popping up that I thought I had fixed.
1) When purchased it intermittently would not start. No crank, no start, just nothing when the key was turned. Then later it'd start right up.
2) Following advice on threads here and elsewhere, I replaced the Ignition switch. This did not fix it.
3) I changed the starter motor. The motor I took out was clearly a reconditioned unit, so the new motor I put in was at least the third starter in this car. After putting in the new starter, everything ran great until...
4) Today, went to start it, and again - no crank, no start.
5) Ran errands in another car, came home, and it starts again.
I guess the starter or the switch could be faulty. But it seems like there's likely something else that is either burning starters out or otherwise causing problems.
My cheap OBDII scanner only reports a P1415 error (Mass or volume air flow too low) that I think it tied to a tear in the air intake boot (replacement on the way). But I don't think that's related.
Any ideas?
Any ideas?
