Hello everyone,
This is my first post and I would like to say how nice it is to find a great community for such a low volume car!
I am a happy owner of an 06 Z4MR with 29k, in Interlagos blue with tasty trimming such as Logic7, Prof Nav, Bluetooth. Happy until a couple of things...
1. The engine management light came on the other day. After getting a friend of a friend with the relevant diagnostics tool to find the fault code, I have three codes which, from Google, are described as:
P1633 Throttle Valve Adaptation; Limp Home Position
P114B Post Catalyst Fuel Trim Via Oxygen Sensor System Too Lean (Bank 1)
P2196 O2 Sensor Signal Stuck Rich
Any idea what these mean?
2. The front end of my car has always produced creaking noises over uneven surfaces, especially over speed humps (there's a lot in London). I had the anti roll bar changed which didn't really fix this. After reading this forum, I had the nuts on the strut brace torqued up which seemed to reduce the creaking somewhat. This has however returned. Do these require constant torquing or is this caused by something else?
After driving a friend's Z4MR, it is also apparent my car is a lot more nervy in terms of front end grip. The only difference is that I have Avon ZZ3s (with plenty of tread) and he has Contis, but I doubt this is the cause. The bushes have been checked and given the all clear. I am thinking this will be related to the above problem as creaking would suggest movement at the front. Any help would be appreciated!
In the meantime, here is the car in question after a nice clean..
Many thanks,
ic5mav
Many thanks,
ic5mav
