Newbie After bit of Z4 advice and help
Scharnhorst
Suffolk
Just bought last week a 2011 model year Z4 23i Auto with 58k on the clock, Full BMW history, Alpine white with I guess a few factory extras when new, leather seats, sat nav, park sensors, autobox.
Now I am not new to BMWs as I have a 2016 330d M Sport saloon but struggling with a few features as no hand book.
1. Is it possible to get paper owners/operator manual for the car, I have tried google without much luck?
2. I have found out the key fob will lower and raise the roof, but have not tried raising the roof on the move, is it possible or simply not recommended on the basis the extra wind resistance will strain the motors?
3. I am getting the impression sliding the gearbox into S is making the engine and exhaust sound even better or is this in my head?
4. Is the rocker switch with Sport and Sport + worth using. I don't use it on my 330d but that engine is all about torque rather than revs?
5. The current tyres are Run Flat Bridgestones 225/35 x 19 front and 255/30 x 19 rear, the fronts are looking a bit perished ( just passed the MOT) and I would not be surprised they are original, any recommendations on a better tyre, I was thinking Goodyear F1 Eagle or Pirelli RF, low noise rather than ultimate grip is my aim
6. Finally the paddle shifts have completely confused me, my 330d is left for a change down and right paddle for a change up, no idea what left and right is doing on the Z4 as seems both do same thing?
So far very impressed with the build on the car, the sound system (looks like I have 10 speakers if the maths is right) and the engine/exhaust sound is amazing. I also got 37mpg on a 80 mile run, but expecting 20-25mpg locally.
Any advice/help appreciated. Thanks :)
1. Could try Ebay, they can also be found in digital format online.
2. If I remember correctly the pre-LCI (which yours is) need to be stationary to operate the roof.
3. No experience of your gearbox, but could it just be that it holds the gears longer therefore staying at higher revs and making more noise?
4. Again, not sure on your particular model, but on my 30i I think sport/+ just changed the throttle response a bit and turned off some assistances - wasn't hugely noticeable.
5. Apart from standard issue Bridgestone RF's I've only used my current Michelin PS4S on a Z4 and they are brilliant to drive on but definitely not the quietest so you should probably rule them out. You will soon be bombarded by "ditch the runflat" responses, which I would agree with - I think I've heard that the Goodyears are good for noise.
6. Pre-LCI they are push/pull or pull/push for up/down or down/up.
7. Apologies, I thought I was going to be more helpful than I actually was - some more knowledgeable people will no doubt comment soon!
I spotted a white 23i in Hadleigh this week, although I think I've seen it there before so probably not yours - either way, e89's look great in white and that 6 cylinder engine is glorious :thumbsup:
P.S. welcome!
Hello and welcome to the forum, great choice of car and colour, but I am biased.
1 - As Tiglon advised or even BMW direct.
2 - Only raise the roof off the key fob unless you have a comfort access. You can get a smart top at £350 new (cheaper used) and easy to fit will give loads of additional features.
3 - No idea on the gearbox
4 - As Tiglon has said
5 - Get rid of the RFT and most will say Michelin but some will name other tyres but its your preference
6 - As Tiglon said - everyone says its confusing
Hi and welcome to the forum, photos are highly recommended with your 1st post,
The roof normally only opens with the key fob unless you have comfort access or an aftermarket module fitted (smart top)
My 2011 will raise and lower the roof whilst moving, if I remember correctly it will do it up to 10mph as standard but can be coded to work at upto 30mph, personally I’d only do it on a smooth road at less than 15mph.
The sport/sport + alters the throttle response, steering weight and possibly an exhaust valve if yours has one, also stiffens the suspension if you have adaptive suspension.
As already said your paddle shift works up/down either side, a few people have changed them to the later design, one side up the other down, but this is the first DCT I’ve had and I like using one hand for up and down changes.
Hi I've got an identical car:
The auto box is more fun to drive when switched to s mode, s+ can catch you out.
The paddles are rubbish and thats why I've changed mine to the newer ones. Ditch the runflats, roof will only open from key fob not close
As said previously ,keep your eyes peeled fo a Smarttop module - About £200 used - the best money you can spend on the E89 :thumbsup:
Welcome to the mad house. :)
Can't help much with your questions , other that Don't buy Michelin Pilot Super Sport tyres. They are perfect for ultimate grip on dry roads and little else. :D :driving:
The picture police are closing in too, so best get a few pictures of this fine new beast up on the forum. :wink:
At launch the models didn’t allow roof movement on the move but were I think all reprogrammed so that the roof can operate upto 20mph or 25mph as standard ..you can program it to move upto 30 mph..mechanical sympathy suggests taking any head wind into consideration that 15-20mph is more benign to the roof..
The mode button on yours affects throttle, steering and gearbox shift points..with a modestly dynamic model the changes may not appear significant..
I thought it was possible to get the roof to open / close on etc move with comfort access on the 23i? :?
Hi and welcome aboard. :thumbsup:
I've never had an E89 so can't offer much help. But I'd agree with what buzy said about the MPSS tyres. I picked my current car up over 150 miles from home fitted with those tyres on a cold grey December day with everything from drizzle to heavy rain and they were hopeless! But I think they may have been discontinued now the PS4s are on sale.
Has anyone mentioned photos yet? :lol:
I’m slightly confused..if you have the key in its ignition slot how do you press the buttons whilst on the move?
Me to Pete, I was under the impression that the roof could only be opened / closed with the interior buttons when stationary, the key fob would allow you to open the roof when stationary only - no comfort access.
I thought comfort access gave different parameters and allowed the interior buttons to open / close the roof when on the move (as per smart top) as well as open when stationary - not certain about close off the fob when stationary.
Thought there was also something about boot access as well with comfort access, not certain what or how it functioned but was meant to provide easy access to items in the boot by partially opening?
I could be wrong that's for certain as I do not have comfort access but fitted smart top and can open / close off the fob when stationary and the same when moving upto 40mph (not that I would do that above 10 / 15 mph) :)
Comfort access is depending on the market the ability to remotely open and maybe close windows / locks / roof…
The switches in the central console open and close the roof irrespective of whether you have a comfort access version.
For National market regulations you have to hold the buttons whilst either opening or closing the roof.
Windows with anti-trap sensors are allowed to have one touch opening and closing..
The maximum speed you can open and close the roof has changed over time..you can program it up to a hard limit of 30 mph.. :thumbsup:
The switches do allow you open / close the roof clearly but not when moving was my understanding unless you have comfort access?
Not so AFAIK.. :tumbleweed:
There is some confusion over ‘comfort access’…
BMW comfort access is when you approach a locked car with your key in day your pocket and it automatically unlocked the car without your intervention..very few E89s were ever fitted with it..
AFAIK all E89s have a remote unlocking capability.
I got rid of those god awful Bridgestones and replaced them with Goodyear Assy 5 and never looked back - quieter and the traction light doesn't come on as often in cold, wet weather
Pete, totally agree that very few cars have comfort access and that allows you to touch the ribs on the door handle to local / unlock the doors and start the car with the key in your pocket.
Yes all e89 have remote unlocking.
it is the roof functionality that is a further differential between cars with and without comfort access, such things as convenient loading (easy access to boot) when comfort access is fitted, press once and then again within one second press and hold and the roof opens but the rear section stops at the top of the cycle and the boot opens.
Same with open / closing of the roof, with Comfort Access you can open close the roof off the key fob when stationary or the buttons when moving, cars without comfort access do not have these functions other than you can open the roof off the key fob AFAIK.
This is why people fit smart top - gives same functionality as comfort access in regards to the roof
My car doesn’t have comfort access..I can do all the functions you’ve listed..the only thing smart top gives on top is the ability to remotely close the roof…
