New wheels, Rubbing?
jjr197 said:
Based in Basingstoke
Of no help to you here, but nice to see a fellow Basingstoke Zed owner! If I can help in any way, shout. I know a very good mechanic who works on my Zed.
Easy way to check if the star has been fitted to the correct barrel is to measure the depth of the bolt holes. The rear ones should be deeper than the fronts. It's easy to tell as I could feel the deference on my 108's when washing with a mitt.
I have this exact same issue after fitting my winter 108 tyres, my Summers tyres are more offset so ok.
Mines only rubbing on the nearside, if you full lock the car when stationary and look behind the wheel you'll see it sitting against the strut. Fyi, I replaced my shocks but still getting the same issue. I am lowered but have zero issue on offside of the car, be interested to see if you solves this. I've had mine looked at several times without answer and was advised to next replace the whole knuckle section incase it was bent...
Looks like it's running more negative camber than usual on the front. Mine are approx -1.4-1.5 and I'm lowered on eibachs with no rubbing.
I had my wheels off today to and checked for any marks on my struts from when i had these on and there are no marks on mine at all, got to be a suspension issues
Hi,
The angle of strut and hub/disk face are fixed, and no amount of camber angle will alter that relationship. It must be a wheel/tyre offset problem - anyone out there with a set of 108's who measure up between the hub mounting face and the outer edge of the rim?
Good Luck!
Stu.
stupot67 said:
Hi,
Good Luck!
Stu.
a bent strut or knackered ball joints would
bamberjim said:
stupot67 said:
Hi,
Good Luck!
Stu.
Hi,
Bent strut maybe (But to bend it bad enough to lose the clearance i think the OP would have other handling issues), but bottom ball joints will make no odds to the angle between disc face and strut, dont forget the strut body inserts into to the hub carrier and is retained with a pinch bolt, any movement in the TCA or its ball joints will not effect this.
Stu.
stupot67 said:
bamberjim said:
stupot67 said:
Hi,
Good Luck!
Stu.
Hi,
Stu.
So how would they not rub on one z4, removed the same day the op picked them up then rub on his car..
RJS-Z4 said:
jjr197 said:
bamberjim: Well I was 100% that I checked until people started asking! :-)
Jingle: No spacers fitted.
I'll get it jacked up again tonight and have a look.
Don't jack it up, just use a tape measure.
The reason I say that is because I've seen it before where someone has bolted the wrong star (face) to the wrong drum (that's assuming you've got 108 split rims). So just measure the inside of the wheel drum on the front and rear.
So I obviously didn't read this properly when it was first posted. Apologies to RJS-Z4!
This was exactly the problem. Refurbed wheels with the Stars put onto the wrong drum.
All sorted now.
Thanks to everyone for their thoughts!
All sorted now.
*takes a bow*
My modesty astounds you, I know.
But really, glad to be of service :)
