New tyre's pressure advice
gideon87
 Sussex
Hi all i recently got new alloys for my Z4
front 19" 8.5J ET35 225/19/35
rear 19" 9.5J ET35 255/19/30
and on the tire pressure sticker it shows 2.3 and 2.7 bar for the 18inch options does anyone no the correct PSI/Bar for the new set i have
When I had those size tyres fitted, I just used the standard pressures of 33psi fronts and 36psi rears. Seemed fine, if a little bumpy/firm, but that was probably down to the elastic band width side walls :cry:
I use 34 front 36 rear during winter and 36 front 38 rear during summer on my 19”s because of the terrible Greek roads.
This. 255/30 is going to hurt, whatever pressures your choose!
I wouldnt go above those numbers (33 & 36psi ) especially with those tyre sizes on 8.5j & 9.5j rim widths :cry: zero comfort for the driver & zero protection for the wheels :( , hope its not a daily driver op as that is surely going to end with a buckled or split rim
Go any lower than those though and it'll look like you have 4 flat tyres. You'll also meet loads of nosey buggers who want to tell you all your tyres are flat :lol: happened to me loads of times.
