New to me Z4 from Madison, Wisconsin
madtownZ4
Just picked up a 2005 Z4 3.0i 6 speed manual with 141K miles. It was throwing engine codes and the suspension was pretty bad when I got it. The power top also doesn't work. I have replaced the shocks, struts, mounts, bumps stops and belows a long with the sway bar links. I still had a rattle that went away when I tightened the struts brace nuts. The engine code was a 'bank 1 or 2 too lean'. I found a video that pointed to the throttle body boot. Sure enough, it was torn so I replaced that. The car is now running really nice (knock on wood). I am really happy with it.
I did relocate the to motor to the trunk. It was low on hydraulic fluid. As I added more fluid and ran the top, I could see a puddle of fluid coming out of the driver side drain holes onto the ground. I suspect a hose or hinge. Seems much more involved than just replacing the motor unfortunately...
Anyways, I can easily open and close the top manually from in the car. Thanks for adding me to the forum and thanks for all the help I have already received fixing the above things.....
As you've ben on the forum a while, welcome to Z4 ownership. :thumbsup:
It sounds like you have been pretty busy improving your car so I hope you can sort that hydraulic leak.
Welcome. I’d guess you just need the short lower hose (number 12). Not too hard to do.
You only need to lift the left side of the roof, not remove it completely.
