New springs
Jollyjoiner
 Chesterfield
Well I finally managed to get the new front brake discs and pads on and also the cars Eibach pro springs which make it 20mm front 10mm rear lower. Happy with the height now. I've also ordered some wheel spacers, 10mm rear 5mm front.
These wheels will stay on until the tyres are getting ready, then I'll swap them.20190607_101757.jpg
Looks great, sounds great with the Milltek and will leave my stock 35is for dead with the remap, it’s a bit of an animal.... :o :driving:
Cheers John we will have to compare cars once you've done all your tweaks
Hi Jolly,
Looks fab, best colour combo IMO.
Is it this spring kit you fitted
https://www.eibachshop.co.uk/eibach-prokit-performance-spring-kit-e10200190122_p31223213.htm#.XPuo59NKi88
Has the Eibach springs affected the ride quality?
10mm and 5mm would mean you won't be running a hub centric setup.
However, with 12mm and 3mm you will.
Just thought I'd let you know. :thumbsup:
I can tell you that going from m sport suspension to eibachs (19" wheels), the ride is definitely better due to the progressive springs and the m sport springs being so stiff to begin with.
