Problem is if I hadn't seen this thread I wouldn't have noticed my rear was a tad high. I've had the car a year now and didn't realise my car has had replacement non Sport springs fitted but the clearance wasn't as large as that on Chappio's car.
I think they are Kilen -Lillywhite said:The garage should have supplied the last seven digits of the VIN number to get the correct coil springs for M Sport suspension. In addition M Sport springs have three green (OEM) or grey (Suplex) blocks painted on halfway down the spring.
I hope the garage sorts ASAP for you. Out of interest, what make of spring was fitted?
ASW28 said:The Suplex catalogue shows the 2.0i with options, as well as without, with two different springs. What are the options ? :?
Wondermike said:The non-M models have different spring part numbers depending on final spec, options fitted, etc.
http://www.z4-forum.com/forum/viewtopic.php?p=151619#p151619
gannet said:Spring table is hidden in the ETK - under 'Parts Search - Specific - Spring Table'
for my car which is an 04 3.0 SE with MSport (as I believe they all are?) Part numbers are:
Front: 31336760622 or 3
Rear: 33536761925 or 6
... But it does ask you what options you have fitted (such as electric seats, SMG, Stereo system, Headlight cleaning)... some of those options seem to change the part numbers slightly :?
Edit: For example, screenshot here:
ASW28 said:I have relayed this info to the garage, and am waiting to hear back, although their supplier maintains that the Kilen 51042s are the correct fitment !![]()
