enuff_zed said:That's nearly a quarter hour now and you've not fitted it.![]()
dhobbs said:enuff_zed said:That's nearly a quarter hour now and you've not fitted it.![]()
Working from home, so it's partially fitted. Need to find the torque value for the big bolt.
enuff_zed said:dhobbs said:enuff_zed said:That's nearly a quarter hour now and you've not fitted it.![]()
It's always the nut that holds the wheel that causes the problem.![]()
kis said:enuff_zed said:dhobbs said:Working from home, so it's partially fitted. Need to find the torque value for the big bolt.
Well good job, mine is a bolt then![]()
IIRC from when I did mine its 46ft/lbs or 62Nm. Check with TIS first thoughdhobbs said:enuff_zed said:That's nearly a quarter hour now and you've not fitted it.![]()
dhobbs said:OK. So answered my own question, the three bolts that hold the plate down do need to be screwed all the way in. This plate is for the horn as well and when screwed in, there is a small amount of play as you'd want.
All back together again.
dhobbs said:Fitted.
