Hi
So when not out in the car I am working through the following to do list,
Change brake fluid
Clean and protect roof - done, Autoglym kit
Renovate headlights - done
Full detail
Set up DSP using forum guide - done (amazing difference!!)
Throttle rest - done
Check front wishbone bushes (ongoing....help!)
Resonator mod - done
Check DISA valve - done and like new
Replace split intake ducting causing whistling - done
Fit battery conditioner - done
Clear roof motor drains - done
Deep clean wheels and arches - done but could do with a refurb or CSL!
Remove and clean/Glimtone seats - done
Wet vac and shampoo carpets - done while seats out
Upgrade sat nav to v32 and 2015 disk - done
Replace aerial - mmmm, started
Grease leaking from metal part of n/s/r cv joint
Cure squeak from roof remote release - done, peace at last!
Oil and filter change - done
Change gearbox and diff oil
Add sound deadening to the doors to stop tinny Citreonesque noise!
I am happy with everything about the car except a few bits of paintwork and the steering.
I have checked the bushes and all joints and they look ok but it does pull and wander, it does have run flats and needs an alignment check but I just can't help thinking it's the bushes, anyone local want to drive it and compare?
In return I have a full snap on verus diagnostic kit that I am happy to help anyone out with. I am a trained tech so can probably help someone out.
John
