new facelift fogs -how to fit
Gjm91
 Southport
Hi all bought 2 new facelift fog-lights from car parts for less as tried all methods without sucess to get rid of that horrible condensation- seemed a bargain £115 for the pair with a 17% discount code . Tried to find a how to fit guide without luck - a few posts say they are easy to fit but dont provide much detail- anyone fit these and if you have could you give me a brief step by step guide - thanks in anticipation :thumbsup:
Lift front and remove wheels; open access flaps in the wheel arch on the back of the bumper; you can now reach in and disconnect then unscrew the old ones (some screws are on the front if I recall correctly). They look like they won't come out but they will they just need rotating a bit to get through the hole - then its the reverse to fit the new ones :thumbsup:
if yer lazy, you can do it without taking wheels off, but tbh its just as quick doing it with bumper off comes off in 10 mins and its less working threw a small gap
It's easy peasy. Probs easiest with Bumper off, since bumper off is like 10min job and less of a headache IMO
Be warned. If you try squeezing the fog lamp out through the inspection flap in the wheelarch, don't dislodge the pipe to the washer jet. I did this and uleashed a small pool of washer fluid on the floor!
Also, i think the 3 screws on each fog lamp are torx head, so make sure you have the right tool.
