More updates. Spent some time giving the paint some much needed tlc. Time to give the tired looking paint a new lease of life.
Started with a hose down. Was pleased to see that it had some form of wax on it applied, and relatively recently at that.
IMG_3409 by
Neil Patel, on Flickr
IMG_3410 by
Sprayed the car with a mixture of degreaser, APC, and some Fairy liquid.
IMG_3411 by
APC was then sprayed around and agitated with a brush.
IMG_3413 by
The front grills were removed and hit with some APC as well.
IMG_3432 by
Next up was the actual wash. Wanting to remove as much of the existing wax as possible, I opted for Fairy liquid. Lots of suds!
IMG_3418 by
Rinsed the car and it was then time to clay the paint. As per the instructions I only used water as lube with great results.
IMG_3434 by
Judging by how much clay I got through, the paint was in pretty bad shape with regards to surface contaminants. This was after one pass over a portion of the bonnet.
IMG_3436 by
I wanted to make sure that the surface was as clean as possible so the car was hit with a spritz of Iron-X. Pretty hard to capture the bleeding from the black paint, but the wheels had a fair bit.
IMG_3441 by
IMG_3444 by
Rinsed the car again before hitting it with the DA to reveal some pretty bad swirls and some deep scratches.
IMG_3447 by
IMG_3450 by
I started off with two passes with Meguiar's DA Microfibre cutting compound followed with two passes of Auto Glym's Ultra Deep shine. Unfortunately I only managed to finish compounding the car before calling it a day.
IMG_3453 by
IMG_3462 by
Started the next day with passes of Ultra Deep Shine.
IMG_3464 by
Now for the protection stage. To complement the compound, a coat of the DA finishing wax was used. Following that a I moved onto two coats of Meg's #16. One coat applied by hand, another with the DA.
IMG_3468 by
Lastly, the car was finished with a coat of Liquid Wax on top.
IMG_3476 by
Which resulted in the car looking much more presentable in my opinion. Complements the coupe nicely now!
IMG_3482 by
Oh and the exhaust tips were removed, cleaned, dab of of Autosol and refitted.
IMG_3489 by
Concluding thoughts; the paint is far from perfect, but she's scrubbed up nicely considering the age! Next for the car is a new rocker cover gasket and CCV hoses. If you made it through to the end, treat yourself to a nice cold brew!
