2004 2.2 m54 running negative long term fuel trims
Car has had new plugs, coil packs, vanos seals, thermostat, water pump, rebuilt fuel injectors and new continental maf.
Bank 1 has a multiplicative mixture adaptation of -4.52
Bank 2 has a multiplicative mixture adaptation of -5.07
Catalyst monitor will not set but the bmw drive cycle to set it isn't easy to follow especially when the roads are busy, also keep getting fault for Bank 2 sensor 2 heater even tho car completes o2 heater monitor. I have 4 new oxygen sensors for the car but I'm on the fence about changing them as by all accounts they are very difficult to remove.
Dme reports current atmospheric pressure as 1000.94 Met Office app for my area states 1010.02 portable weather station I have states 1010 also.
Car runs and drives fine and for all I know it's always run negative or something related to the work I've done to the car has caused it.
