Scooba_Steve said:Take of the footwell trim below the fuse box. Reroute your blue wire along the bulkhead, a few cable ties to secure help (but not too tight initially).
A nut on some string fed through the electronics box in the engine bay then tape the wire to it and pull back up. Make sure you know which pin you're connecting to, the BMW instructions are wrong for a few models.
Scooba_Steve said:What model and build date (or VIN)? I'll check WDS
Scooba_Steve said:X60002 should be the one to the left of the right most block of them all in a line and I wouldn't expect it to be white.
A6000 DME control unit
Plug connector overview
X60001 26-pin, grey Component connector DME control unit
X60002 26-pin, black Component connector DME control unit
X60003 6-pin, black Component connector DME control unit
X60004 6-pin, black Component connector DME control unit
X60005 44-pin, black Component connector DME control unit
X60006 12-pin, black Component connector DME control unit
X60007 26-pin, natural Component connector DME control unit
Scooba_Steve said:I don't think they are labelled, are you counting from the right end? 26 pin connectors are usually split into 2x 13 pins, sometimes all numbered, sometimes just the first and last.
You can't connect to any other pin, though if you put it in an incorrect empty one it *shouldn't* cause any issues but don't take that as gospel.
