Hi
Z4 roadster '08 is popping a 5A fuse when the engine is running and the climate system switched on. It's fuse 10 on the diagram below. Now the odd thing is, that when the climate system is off, everything else works fine (locks, interior lights which are on the same fuse). Once the fuse has popped, I have no door locks, interior lights, windows etc. The heating system seems fine though, blower and temperature controls work!
In the fuse diagram fuse 10 seems to cover an item with a thermometer which I assume is the part causing the problem, but I can't seemt o identify it. Can anyone tell me what part of the climate control system it refers to?
