Do you mean how you can put a 'deflector' or something inside the headlight to stop the beam pointing towards oncoming traffic -Niallc said:Changing the direction of the lamp is no problem. Im driving an Irish Z4 in SwedenSo about those spare headlights ?
enzed4 said:Another thing: mine are facelift, so you'd probably need both left and right for a matching pair. They're also auto-levelling, but I don't know if the pre-facelift E85's had the motor for this? You can see them 'bounce' up and down a couple of times when you first turn the headlights on.
Can you explain the 'bounce' I had on my E85 with Halogens? I think I've seen this comment before, where if the headlights are auto-levelling, they 'must' be xenons. The headlights have 'H7' engraved on them which are the halogen bulbs. The parts that should have xenons in them are empty as far as I recall.IAmOrion said:enzed4 said:Another thing: mine are facelift, so you'd probably need both left and right for a matching pair. They're also auto-levelling, but I don't know if the pre-facelift E85's had the motor for this? You can see them 'bounce' up and down a couple of times when you first turn the headlights on.
My E85 Xenons are auto levelling. I thinks it’s only halogens that require manual levelling.
