Name these electrical connectors...
As I mentioned in another post (https://z4-forum.com/forum/viewtopic.php?f=3&t=118033) I recently acquired a 2004 Z4 from my brother in law. It needs some work and a thorough cleaning. I've been going through the car to clean it up and came across this set up electrical connectors/boxes and I'm hoping that you all can identify them for me. I've labeled them numerically in the images below. Please tell me what each of these are for.
Between seat under the rear storage box
In the truck on left side against the back wall
On the driver's side (LHD) B-pillar behind the speaker trim panel
On the passenger's side B-pillar behind the speaker trim panel
From what I can see in the photos, 4 and 5 are definitely the pre-wired for CD Changer wires
I’d hazard a guess that based on the location of some of the wires, it has the Oem Bluetooth system but parts of it aren’t connected
13 = Folding top module 6135719999
10, 11, 12 are part of the wiring harness for the soft top, they need to be disconnected when removing the top.
srhutch said:
What are you trying to fix/achieve that you need to know all these connections?
At this point in the ‘recommissioning’ process, I just like to know what I dealing with.
I’m a pretty experienced home mechanic but this is my first BMW. My other daily vehicle is a 2008 Jeep Wrangler which is simple compared to this car. I’ve also got a 1967 Lotus Elan that I’ve been restoring.
Admittedly, mine is a coupe, but I just removed the audio wiring.
4&5 are 100% CD changer wiring (if you want to add a Bluetooth module you can get one for these too)
4 definitely isn’t the storage light as suggested above - the storage light switch is literally a pressure switch that is pushed when the door opens (and is obvious when you see it)
Softop CVM module and plugs are on the opposite side of the wiring in your pic (passenger side on RHD). Well, they would be if you didn't have a coupe :D
