N54 engine ownership guide
Good read.
I get codes for the HPFP and turbo actuator on the wifes 335i
Looks like an invoice coming.
There are some common issues with the N20 versions too..
Cam box and gasket
Water pump
Oil changes
Oil Cooler and gasket
Cam box and gasket
Water pump
Oil changes
I’ve not read of anyone changing a water pump on an n20 yet, I’m presuming it’s equally as simple as the n52 is? :?
Smartbear said:
Cam box and gasket
Water pump
Oil changes
Same pump type so assume its a matter of time for us N20 owners, not that many high milers yet..
Smartbear said:
I don't know, Rob. I do know, though, that they don't recommend walnut shell blasting or snake oil massage.
In all seriousness, Rob, walnut blasting can cause significant damage if the debris left from the process is not completely removed.
Even a little walnut 'grit' left in the engine will do a damn sight more damage than any carbon it's used to remove.
That’s surprising, i would have thought the engine could ingest the walnut shell without harm? :?
Apparently not, which, considering its function as an abrasive, is perhaps not surprising.
Anyways, I ain't lettin' none o' those techie folks put any nutty bits in my car.
Smartbear said:
Denial :lol:
Seriously, a quick search found many references to BMW dealers carrying out this service. I read that to mean it is BMW approved/recommended. So I'm not sure why Busterboo says it's not approved. Unless he just meant 40,000mi is not the BMW recommendation? Hard to tell. I found one reference that said BMW recommends 30,000mi but it wasn't on a BMW website so I wouldn't take it as gospel.
By "dealers" do you mean dealers who sell used BMWs? Or ADs - dealers authorised by BMW to import & sell new cars?
Walnut shell is only a harder medium than the carbon deposits though, it’s not as hard as the steel & alloy within the combustion chamber. After all when it’s blasted into the intake ports it doesn’t harm the valves or port in anyway does it? :?
Smartbear said:
The danger lies in the failure to remove any remaining abrasive medium and the combined residue of medium & 'dirt' after cleaning. This applies to all abrasives, of course, and not only walnut shell. However, if a car owner's happy the techie's doing this, fine.
That said, the use of walnut shell was discontinued by the aviation industry a long time ago (or so my cousin, who works for R-R, has told me).
I'm not familiar with the difference. Here a 'BMW dealer' is a BMW approved sales (and usually maintenance) facility. Anything else is just a car dealer regardless of the brands they sell. I wasn't aware there's a difference so when I read BMW dealer I took it to mean BMW approved.
